Не стартует apache
vadimsher
Не стартует apache
Сообщение vadimsher » Вс май 10, 2020 3:24 am
Не стартует apache2 в чем проблема?
root@vm-9699334a:~# apt-get install apache2
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
apache2-bin apache2-data apache2-utils libapr1 libaprutil1 libaprutil1-dbd-sqlite3
libaprutil1-ldap liblua5.2-0 libnghttp2-14
Suggested packages:
www-browser apache2-doc apache2-suexec-pristine | apache2-suexec-custom
The following NEW packages will be installed:
apache2 apache2-bin apache2-data apache2-utils libapr1 libaprutil1
libaprutil1-dbd-sqlite3 libaprutil1-ldap liblua5.2-0 libnghttp2-14
0 upgraded, 10 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/1,790 kB of archives.
After this operation, 7,127 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Selecting previously unselected package libapr1:amd64.
(Reading database ... 73415 files and directories currently installed.)
Preparing to unpack .../0-libapr1_1.6.3-2_amd64.deb ...
Unpacking libapr1:amd64 (1.6.3-2) ...
Selecting previously unselected package libaprutil1:amd64.
Preparing to unpack .../1-libaprutil1_1.6.1-2_amd64.deb ...
Unpacking libaprutil1:amd64 (1.6.1-2) ...
Selecting previously unselected package libaprutil1-dbd-sqlite3:amd64.
Preparing to unpack .../2-libaprutil1-dbd-sqlite3_1.6.1-2_amd64.deb ...
Unpacking libaprutil1-dbd-sqlite3:amd64 (1.6.1-2) ...
Selecting previously unselected package libaprutil1-ldap:amd64.
Preparing to unpack .../3-libaprutil1-ldap_1.6.1-2_amd64.deb ...
Unpacking libaprutil1-ldap:amd64 (1.6.1-2) ...
Selecting previously unselected package liblua5.2-0:amd64.
Preparing to unpack .../4-liblua5.2-0_5.2.4-1.1build1_amd64.deb ...
Unpacking liblua5.2-0:amd64 (5.2.4-1.1build1) ...
Selecting previously unselected package libnghttp2-14:amd64.
Preparing to unpack .../5-libnghttp2-14_1.30.0-1ubuntu1_amd64.deb ...
Unpacking libnghttp2-14:amd64 (1.30.0-1ubuntu1) ...
Selecting previously unselected package apache2-bin.
Preparing to unpack .../6-apache2-bin_2.4.29-1ubuntu4.13_amd64.deb ...
Unpacking apache2-bin (2.4.29-1ubuntu4.13) ...
Selecting previously unselected package apache2-utils.
Preparing to unpack .../7-apache2-utils_2.4.29-1ubuntu4.13_amd64.deb ...
Unpacking apache2-utils (2.4.29-1ubuntu4.13) ...
Selecting previously unselected package apache2-data.
Preparing to unpack .../8-apache2-data_2.4.29-1ubuntu4.13_all.deb ...
Unpacking apache2-data (2.4.29-1ubuntu4.13) ...
Selecting previously unselected package apache2.
Preparing to unpack .../9-apache2_2.4.29-1ubuntu4.13_amd64.deb ...
Unpacking apache2 (2.4.29-1ubuntu4.13) ...
Setting up libapr1:amd64 (1.6.3-2) ...
Setting up libnghttp2-14:amd64 (1.30.0-1ubuntu1) ...
Setting up apache2-data (2.4.29-1ubuntu4.13) ...
Setting up libaprutil1:amd64 (1.6.1-2) ...
Setting up liblua5.2-0:amd64 (5.2.4-1.1build1) ...
Setting up libaprutil1-ldap:amd64 (1.6.1-2) ...
Setting up libaprutil1-dbd-sqlite3:amd64 (1.6.1-2) ...
Setting up apache2-utils (2.4.29-1ubuntu4.13) ...
Setting up apache2-bin (2.4.29-1ubuntu4.13) ...
Setting up apache2 (2.4.29-1ubuntu4.13) ...
Created symlink /etc/systemd/system/multi-user.target.wants/apache2.service → /lib/systemd/system/apache2.service.
Created symlink /etc/systemd/system/multi-user.target.wants/apache-htcacheclean.service → /lib/systemd/system/apache-htcacheclean.service.
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
invoke-rc.d: initscript apache2, action "start" failed.
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: failed (Result: exit-code) since Sun 2020-05-10 03:14:46 UTC; 10ms ago
Process: 4413 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
May 10 03:14:45 vm-9699334a systemd[1]: Starting The Apache HTTP Server...
May 10 03:14:46 vm-9699334a apachectl[4413]: AH00534: apache2: Configuration error: No MPM loaded.
May 10 03:14:46 vm-9699334a apachectl[4413]: Action 'start' failed.
May 10 03:14:46 vm-9699334a apachectl[4413]: The Apache error log may have more information.
May 10 03:14:46 vm-9699334a systemd[1]: apache2.service: Control process exited, code=exited status=1
May 10 03:14:46 vm-9699334a systemd[1]: apache2.service: Failed with result 'exit-code'.
May 10 03:14:46 vm-9699334a systemd[1]: Failed to start The Apache HTTP Server.
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for systemd (237-3ubuntu10.39) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for ufw (0.36-0ubuntu0.18.04.1) ...
Rules updated for profile 'Apache'
Skipped reloading firewall
Processing triggers for ureadahead (0.100.0-21) ...
Re: Не стартует apache
Сообщение KyKyIIIKuH » Вс май 10, 2020 7:16 am
в панели уже есть надстройка, из панели устанавливаешь apache2 и радуешься.
зачем в ручную ставите?
ordex
Сообщение ordex » Вс май 10, 2020 7:50 am
А панель уже допилили для работы с debian ??
Сообщение KyKyIIIKuH » Вс май 10, 2020 7:52 am
нет, я не обратил внимания что это debian
vadimsher
Сообщение vadimsher » Вс май 10, 2020 5:49 pm
Нет, это ubuntu.
Что за панель?
Сижу только через терминал pytty
Сообщение KyKyIIIKuH » Вс май 10, 2020 5:54 pm
Нет, это ubuntu.
Что за панель?
в смысле что за панель, BrainyCP
она только под Centos (в данный момент)
vadimsher
Сообщение vadimsher » Вс май 10, 2020 5:56 pm
Так я не под CentOC сижу,а под убунтой и об этой панели ничего не знаю и не слышал, ибо ее там нет)
Сообщение KyKyIIIKuH » Вс май 10, 2020 5:57 pm
это форум по панели BrainyCP
вы заблудились
