yum clean all && yum install -y wget && wget http://core.brainycp.com/install.sh && bash ./install.sh --package=apache2.4,nginx,php56w,php70w,php71w,php72w,php73w,php74w,php80w,bindserver,imagemagick,httpry,certbot,megacli,iotop,atop,iftop,logrotate,git,shellinabox,MariaDB10.5,phpMyAdmin-4.9.4,exim,proftpd,csf
[root@static ~]# systemctl status rc-local -l
● rc-local.service - /etc/rc.d/rc.local Compatibility
Loaded: loaded (/usr/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2021-03-10 19:54:04 UTC; 48min ago
Docs: man:systemd-rc-local-generator(8)
CPU: 116ms
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/terminfo: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/zoneinfo: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/GeoIP: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/mc: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: quotacheck: Skipping /dev/sda1 [/]
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: quotacheck: Cannot find filesystem to check or filesystem not mounted with quota option.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Control process exited, code=exited status=1
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Failed with result 'exit-code'.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: Failed to start /etc/rc.d/rc.local Compatibility.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Consumed 116ms CPU time
А размер каталога пользователя /home/yobane/usr/ занимает около 2.5 GB
Файловая система xfs
[root@static ~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 40G 0 disk
`-sda1 8:1 0 40G 0 part /
sr0 11:0 1 4M 0 rom
[root@static ~]# cat /etc/fstab
# /etc/fstab
# Created by anaconda on Fri Dec 4 17:37:12 2020
# Accessible filesystems, by reference, are maintained under '/dev/disk/'.
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info.
# After editing this file, run 'systemctl daemon-reload' to update systemd
# units generated from this file.
UUID=efba87f2-a6d9-4aa8-9e3c-91de25086f64 / xfs defaults 0 0
